Kicco
Nov 23, 2016Aspirant
DROPBOX SYNC (status)
Hi to everyone. After the factory default reset of my RN204 I set up the dropbox sync to save all my data. I have 4TB of data with big files (medium size 1 to 4 GB) and it's working but the uploadi...
mdgm-ntgr
Apr 11, 2017NETGEAR Employee Retired
We included a major update to the Dropbox service in ReadyNAS OS 6.7.0 which is now available!
Kicco
May 08, 2017Aspirant
Thanks to God (and developers! :-) )
Now it works very well!!
- KiccoMay 11, 2017Aspirant
UPDATE - it freez like the previous DB Client. It stops uploading files.
In this version of ReadyNAS, you can see the log, so, you can be sure that it's freezed.
- araccJul 05, 2017Aspirant
Where is the logs showing this? Thanks for the help. My sync to DB has frozen as well it seems. Even with the latest update.
- KiccoJul 06, 2017Aspirant
Can you see the Log (I waited for it for a long time!) in the Cloud page?
I suppose there's a bug because it tries to upload all the files (not only the modified ones) so it could seems freezed.
