michaelpporter
Mar 06, 2015Aspirant
Dropboxmanager settings issues
I installed Dropboxmanager on a RN314 running 6.2.2 I am not seeing any config for adding the admin or user accounts. I can start dropbox from the command line, but it links it to root. I removed it f...
michaelpporter
Mar 10, 2015Aspirant
Thank you for the reply. I have a post at https://rnxtras.com/forum/dropbox-installer perhaps the wrong thread? I posted there after here realizing it should be the better place for an answer. https://rnxtras.com/topic/dropbox-settings-has-no-controls
Where do I find the betas?
I used the uploader, there are no reported errors.
I will checkout "apt-update update" tonight.
