michaelpporter
Mar 06, 2015Aspirant
Dropboxmanager settings issues
I installed Dropboxmanager on a RN314 running 6.2.2 I am not seeing any config for adding the admin or user accounts. I can start dropbox from the command line, but it links it to root. I removed it f...
btaroli
Mar 10, 2015Prodigy
Please note my edit... a typo... "apt-get update" :) BUT, if you saw no errors in the installation log then that will probably work fine. You'd likely see the certificate error there as well. But just another thing to check in case of issues. :)
