michaelpporter
Mar 06, 2015Aspirant
Dropboxmanager settings issues
I installed Dropboxmanager on a RN314 running 6.2.2 I am not seeing any config for adding the admin or user accounts. I can start dropbox from the command line, but it links it to root. I removed it f...
michaelpporter
Mar 10, 2015Aspirant
last few lines from /var/log/readynasd/install_debpkg.log
Description: Dropbox Manager for ReadyNAS OS 6
The Dropbox Manager will install the latest binaries
of the Dropbox daemon on x86 based ReadyNAS systems. It
also includes a Django based web interface for managing
user accounts and daemon settings.
fv-dpkginstall.awk: success
Successfully installed dependencies for /tmp/dropboxmanager_1.1.8_amd64.deb
Selecting previously unselected package dropboxmanager.
(Reading database ... 44964 files and directories currently installed.)
Unpacking dropboxmanager (from .../dropboxmanager_1.1.8_amd64.deb) ...
Setting up dropboxmanager (1.1.8) ...
insserv: warning: script 'leafp2p' missing LSB tags and overrides
ln -s '/lib/systemd/system/rnx-dropbox.service' '/etc/systemd/system/multi-user.target.wants/rnx-dropbox.service'
No DropBox users defined!
DONE(0): Tue Mar 10 13:44:59 CDT 2015
spooler returns spool_status=0 outbuf=(null) errbuf=(null) is_localapp=1 name=dropboxmanager_1.1.8_amd64.deb pkgname=dropboxmanager
