LaszloFolgerts
Aug 17, 2015Aspirant
Edited posts get removed?
OK, since there's no proper place to adress problems regarding the functionality of the forums, I'll just post it in the same category as where the bugs happened. It seems that every time I try t...
Aug 17, 2015Guru - Experienced User
I frequently edit my posts, and haven't seen this.
You should report this as a bug in this forum: https://community.netgear.com/t5/Community-Suggestions/bd-p/community-suggestions
Please include the browser and the OS you are using.
