Steffko
Jul 02, 2016Aspirant
Error after Restart/Reboot ReadyNAS 716 - PCTV 461 S2 - Device not present !?
Hello everyone ! I really do hope that there is someone out here who can help me with my specific problem: I do use the following configuration: Netgear ReadyNAS 716x with OS 6.5.1, a PCTV ...
BrianL2
Jul 03, 2016NETGEAR Employee Retired
Hi Steffko,
I apologize for the trouble that this has caused you. I suppose the shutdown & reboot cycle is being done manually of via Power Timer. Could you share or tell us the Firmware running on your system?
Kind regards,
BrianL
NETGEAR Community Team
Steffko
Jul 03, 2016Aspirant
Hello Sir !
- Thank you for your quick reply !
Yes, it does not work both ways, neiter with Power Timer, nor after a manual shutdown.
But now I am little bit confused !? Which firmware do you mean ?
I am using ReadyNAS OS 6.5.1 (x86) as I already stated in the first sentence of the description of my problem.
Please, let me know if this is the information that you need or if you need anything else !?
In addition, this has also been a problem with the earlier versions of the OS (6.4.0 and following).
Thank you in advance,
Steffko
- BrianL2Jul 04, 2016NETGEAR Employee Retired
Hi Steffko,
Sorry, I overlooked that information. I may need to check this issue that you have reported with my colleagues who can probably assist you and get back to you as soon as possible.
Thanks for your cooperation!
Kind regards,
BrianL
NETGEAR Community Team- SteffkoJul 04, 2016Aspirant
Hello Sir !
- Thank you so much for your support !
I am really looking forward to hearing from you and your colleagues soon !
Best regards,
Steffko - SteffkoJul 23, 2016Aspirant
Hi Sir !
Thanks for your last reply on my issue from earlier of the beginning of this month !
Any news or updates from you or your colleagues for me !?
Thanks in advance and kind regards,Steffko
- mdgm-ntgrDec 28, 2016NETGEAR Employee Retired
Are you still seeing this?
If so, which firmware version and app version are you running?
