MatthiasG
Jan 02, 2020Aspirant
External storage device is connected but the file system is not recognized.
Hi you All, I have a NAS 424 with version 6.10.2 and now I'm getting: System: External storage device is connected but the file system is not recognized. This error occurs after a external HD...
- Jan 02, 2020
MatthiasG wrote:
Hi you All,
How is the disk formatted? Your NAS supports BTRFS, EXT2/3, FAT32 and NTFS. It doesn't support exFAT.
I don't recommend use of FAT32, as it can't handle large files. NTFS is the best option if you want to also access the files on a PC (though you would need to purchase some software to get write access to NTFS on a Mac).
Jan 02, 2020Guru - Experienced User
MatthiasG wrote:
Hi you All,
