Ringo155
May 18, 2016Aspirant
Firmware update (6.5) - Apps won't start, can't be installed oder deleted
Hi everbody, like most of you I updatet my Readynas 204 today. The update process itself went smoothly, but after the necesarry restart some problems arose. 1. I wanted to update Anit-Virus Plus, b...
- May 19, 2016
Edit: the fix in this post is no longer be needed.
Anyone else having this problem on an OS6 ARM system running 6.5.0 please download (EDIT LINK REMOVED)
If it self-extracts grab the zip file from the trash/recycle bin (if it is moved there). It is most important that you have the zip file that was downloaded.
Restore this zip file via System > Settings > Backup > RestoreYou will then be prompted to do a reboot.
About 4-5 minutes later the problem should then be fixed.
May 18, 2016Guru - Experienced User
If you purchased new, you could try contacting support (being very clear that this problem was caused by the firmware upgrade, so they should look at it for free).
