Ringo155
May 18, 2016Aspirant
Firmware update (6.5) - Apps won't start, can't be installed oder deleted
Hi everbody, like most of you I updatet my Readynas 204 today. The update process itself went smoothly, but after the necesarry restart some problems arose. 1. I wanted to update Anit-Virus Plus, b...
- May 19, 2016
Edit: the fix in this post is no longer be needed.
Anyone else having this problem on an OS6 ARM system running 6.5.0 please download (EDIT LINK REMOVED)
If it self-extracts grab the zip file from the trash/recycle bin (if it is moved there). It is most important that you have the zip file that was downloaded.
Restore this zip file via System > Settings > Backup > RestoreYou will then be prompted to do a reboot.
About 4-5 minutes later the problem should then be fixed.
Canolli
same problem with apps but the NAS is working
BrianL2
May 18, 2016NETGEAR Employee Retired
Hi Ringo155 & Canolli,
Welcome to the community!
Was it the same case if you will install an app manually or via 'Available apps'? We'll look into this issue that you guys reported.
Kind regards,
BrianL
NETGEAR Community Team
- ReadDudeMay 18, 2016Aspirant
I am having the same issue on 6.5.0 upgrade from 6.4.1 on an NS102.
note, I am trying install a new ap for the the first time. i was not installed on 6.4.1....
this is the iDrive 1.00.6 or 1.00.7 versions, both will not install.
- BrianL2May 18, 2016NETGEAR Employee Retired
Hi ReadDude,
Does this happen if you're trying to install apps under 'Available apps'? or via manual upload? Kindly prepare the logs so we can check what caused the problem.
Kind regards,
BrianL
NETGEAR Community Team- ReadDudeMay 19, 2016Aspirant
It fails under both the available apps and manual upload. I tried the available apps version 1.00.6 and manually tried to upload 1.0.7 and 1.0.6 all fail similarly, but I also see the problem of not being able to update the available apps list. it is almost like the device does not appear to be on the internet while my connection most definitely good.
