Ringo155
May 18, 2016Aspirant
Firmware update (6.5) - Apps won't start, can't be installed oder deleted
Hi everbody, like most of you I updatet my Readynas 204 today. The update process itself went smoothly, but after the necesarry restart some problems arose. 1. I wanted to update Anit-Virus Plus, b...
- May 19, 2016
Edit: the fix in this post is no longer be needed.
Anyone else having this problem on an OS6 ARM system running 6.5.0 please download (EDIT LINK REMOVED)
If it self-extracts grab the zip file from the trash/recycle bin (if it is moved there). It is most important that you have the zip file that was downloaded.
Restore this zip file via System > Settings > Backup > RestoreYou will then be prompted to do a reboot.
About 4-5 minutes later the problem should then be fixed.
mdgm-ntgr
May 19, 2016NETGEAR Employee Retired
I have confirmed my suspicions. We will have a fix for this in the next firmware release.
Canolli
May 19, 2016Aspirant
when is going to be next update?
- mdgm-ntgrMay 19, 2016NETGEAR Employee Retired
When it's ready.
- CanolliMay 19, 2016Aspirant
is there anyway to downgrade to previous version, coz i need Plex
- AnonymousMay 19, 2016
If you apply the patch provided by mdgm, you should be able to use Plex again
