invik
May 07, 2012Aspirant
[FIXED] Failing to compile PPP module for 4.2.20 (x86)
Hi everybody, I have upgraded my Ultra 2 Plus yesterday and since I've tried to recompile the PPP modules as I did with the 4.2.19. I've tried everything with the 4.2.20 (I've checked several time...
invik
Jun 16, 2012Aspirant
4.2.21 is fine \o/
Here's what I did:
- Downloaded new 4.2.21 version and associated GPL package : http://www.downloads.netgear.com/files/ ... WW_src.zip
- Unzip.
- The kernel sources are under kernel/2.6.37/linux-2.6.37.6
- I've copied the kernel/2.6.37/defconfig.smp file to kernel/2.6.37/linux-2.6.37.6/.config
- Then I've followed these instructions for the configuration except the last part: viewtopic.php?p=232929#p232929
- Instead I've run the following:
- The /lib/modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/net directory should exist and contain
and the /lib/modules/2.6.37.6.RNx86_64.2.4/kernel/lib directory should contain crc-ccitt.ko
After all this I've upgraded the 4.2.21 with the new image (http://www.readynas.com/download/RAIDia ... x86-4.2.21) and after a couple reboots everything was fine :D
Good luck!
Here's what I did:
- Unzip.
make modules
make modules_install
bsd_comp.ko ppp_generic.ko pppox.ko
ppp_async.ko ppp_mppe.ko ppp_synctty.ko
ppp_deflate.ko pppoe.ko slhc.ko
Good luck!
