invik
May 07, 2012Aspirant
[FIXED] Failing to compile PPP module for 4.2.20 (x86)
Hi everybody, I have upgraded my Ultra 2 Plus yesterday and since I've tried to recompile the PPP modules as I did with the 4.2.19. I've tried everything with the 4.2.20 (I've checked several time...
aarons1
Jun 16, 2012Aspirant
Also, did make modules_install actually create the /lib/modules/2.6.37.6.RNx86_64-2.4/kernel/drivers/net directory, or did you have to make that yourself? I'm actually trying to compile the netfilter modules, not ppp, and I had to manually copy all the .ko's into /lib/modules.../net myself. And it turned out those modules were an "Invalid Module Format." I'm trying again more carefully following your method, and if that fails, I'll try using defconfig.up instead of defconfig.smp.
