agbart
Feb 01, 2025Follower
Google Drive
The Google Drive app is blocked on my Readynas 104. How can I set up a sync to Google Drive now?
Kardano
Mar 15, 2025Luminary
Same problem with my RN316 after factory default. Any solution for this?
- SandsharkMar 16, 2025Sensei
Please explain what you mean by "blocked". What specifically does or does not happen, and what messages do you get?
- KardanoMar 16, 2025Luminary
When I try to setup Google Drive from "Cloud" tab.
I am redirected to choose google account which I do. (NAS is RN316. Unit was factory defaulted after volume became Read Only).
After choosing google account I get this from google and I found no settings in my google account to stop this (but it says that Netgear si not a verified/trusted creator...). On all my other nas is sync with Google drive OK.
This app is blocked
This app tried to access sensitive info in your Google Account. To keep your account safe, Google blocked this access.
- StephenBMar 16, 2025Guru - Experienced User
Are you using an app-specific password for the account?
