mdgm-ntgr's avatar
mdgm-ntgr
NETGEAR Employee Retired
Apr 04, 2013
GPL diff b/w 6.0.0 and 6.0.1
As described on the GPL page, the GPL contains the software code for stuff NetGear uses in the firmware that is developed by 3rd parties. Nice useful downloads for developers, but it can be nice to compare the differences in 3rd party software code used between different versions of ReadyNAS OS. I wrote a script to do this a while back, and recently ran it to compare the GPL code for 6.0.0 to 6.0.1 (it should be noted that there is heaps of software code not subject to the GPL that is used by ReadyNAS OS and thus is not part of the GPL code and thus won't show up in the comparison below) and have pasted the results of my comparison below:
Files 6.0.0/apt-0.9.7.7/buildlib/config.sub and 6.0.1/apt-0.9.7.7/buildlib/config.sub differ
Files 6.0.0/buildroot-2012.11.1/configs/readynasos-arm_defconfig and 6.0.1/buildroot-2012.11.1/configs/readynasos-arm_defconfig differ
Files 6.0.0/buildroot-2012.11.1/configs/readynasos-x86_64_defconfig and 6.0.1/buildroot-2012.11.1/configs/readynasos-x86_64_defconfig differ
Only in 6.0.1/buildroot-2012.11.1: custom
Files 6.0.0/buildroot-2012.11.1/package/Config.in and 6.0.1/buildroot-2012.11.1/package/Config.in differ
Only in 6.0.0/buildroot-2012.11.1/package: llconf
Files 6.0.0/buildroot-2012.11.1/system/skeleton/etc/mtab and 6.0.1/buildroot-2012.11.1/system/skeleton/etc/mtab differ
Only in 6.0.1/buildroot-2012.11.1/toolchain/elf2flt/elf2flt: CVS
Files 6.0.0/cairo-1.12.2/debian/changelog and 6.0.1/cairo-1.12.2/debian/changelog differ
Files 6.0.0/cairo-1.12.2/debian/control and 6.0.1/cairo-1.12.2/debian/control differ
Only in 6.0.0/cairo-1.12.2/debian/patches: 07_cff-subsetting-Ignore-charset-for-non-cid-fonts.patch
Only in 6.0.0/cairo-1.12.2/debian/patches: 08_cff_convert_._to_locale_specific_decimal_point_befor.patch
Only in 6.0.0/cairo-1.12.2/debian/patches: 09_cff_use_correct_size_for_buffer.patch
Only in 6.0.0/cairo-1.12.2/debian/patches: 10_cff_subsetting_widths_can_be_floating_point.patch
Only in 6.0.0/cairo-1.12.2/debian/patches: 11_polygon-reduce_reduce_broken_stopped-edge_continuation.patch
Only in 6.0.0/cairo-1.12.2/debian/patches: intersect-dereference.diff
Files 6.0.0/cairo-1.12.2/debian/patches/series and 6.0.1/cairo-1.12.2/debian/patches/series differ
Files 6.0.0/cairo-1.12.2/debian/rules and 6.0.1/cairo-1.12.2/debian/rules differ
Only in 6.0.0/cairo-1.12.2/.pc: 07_cff-subsetting-Ignore-charset-for-non-cid-fonts.patch
Only in 6.0.0/cairo-1.12.2/.pc: 08_cff_convert_._to_locale_specific_decimal_point_befor.patch
Only in 6.0.0/cairo-1.12.2/.pc: 09_cff_use_correct_size_for_buffer.patch
Only in 6.0.0/cairo-1.12.2/.pc: 10_cff_subsetting_widths_can_be_floating_point.patch
Only in 6.0.0/cairo-1.12.2/.pc: 11_polygon-reduce_reduce_broken_stopped-edge_continuation.patch
Files 6.0.0/cairo-1.12.2/.pc/applied-patches and 6.0.1/cairo-1.12.2/.pc/applied-patches differ
Only in 6.0.0/cairo-1.12.2/.pc: intersect-dereference.diff
Files 6.0.0/cairo-1.12.2/src/cairo-cff-subset.c and 6.0.1/cairo-1.12.2/src/cairo-cff-subset.c differ
Files 6.0.0/cairo-1.12.2/src/cairo-polygon-intersect.c and 6.0.1/cairo-1.12.2/src/cairo-polygon-intersect.c differ
Files 6.0.0/cairo-1.12.2/src/cairo-polygon-reduce.c and 6.0.1/cairo-1.12.2/src/cairo-polygon-reduce.c differ
Only in 6.0.1/cifs-utils-5.5/.pc: applied-patches
Only in 6.0.1/cryptsetup-1.4.3/.pc: applied-patches
Files 6.0.0/cups-1.5.3/debian/changelog and 6.0.1/cups-1.5.3/debian/changelog differ
Only in 6.0.1/cups-1.5.3/debian: patched
Only in 6.0.0/cups-1.5.3/debian/patches: fix_kerberos_auth_local.patch
Only in 6.0.0/cups-1.5.3/debian/patches: fix_russian_japanese_templates.patch
Files 6.0.0/cups-1.5.3/debian/patches/series and 6.0.1/cups-1.5.3/debian/patches/series differ
Files 6.0.0/cups-1.5.3/.pc/applied-patches and 6.0.1/cups-1.5.3/.pc/applied-patches differ
Only in 6.0.0/cups-1.5.3/.pc: fix_kerberos_auth_local.patch
Only in 6.0.0/cups-1.5.3/.pc: fix_russian_japanese_templates.patch
Files 6.0.0/cups-1.5.3/scheduler/client.c and 6.0.1/cups-1.5.3/scheduler/client.c differ
Files 6.0.0/cups-1.5.3/templates/ja/help-header.tmpl and 6.0.1/cups-1.5.3/templates/ja/help-header.tmpl differ
Files 6.0.0/cups-1.5.3/templates/ru/classes-header.tmpl and 6.0.1/cups-1.5.3/templates/ru/classes-header.tmpl differ
Files 6.0.0/cups-1.5.3/templates/ru/jobs-header.tmpl and 6.0.1/cups-1.5.3/templates/ru/jobs-header.tmpl differ
Files 6.0.0/cups-1.5.3/templates/ru/printers-header.tmpl and 6.0.1/cups-1.5.3/templates/ru/printers-header.tmpl differ
Only in 6.0.1/dosfstools-3.0.13/.pc: applied-patches
Only in 6.0.1/e2fsprogs-1.42.5/.pc: applied-patches
Only in 6.0.1/ethtool-3.4.2/.pc: applied-patches
Only in 6.0.1/geoip-1.4.8+dfsg/.pc: applied-patches
Files 6.0.0/glib2.0-2.33.12+really2.32.4/debian/changelog and 6.0.1/glib2.0-2.33.12+really2.32.4/debian/changelog differ
Files 6.0.0/glib2.0-2.33.12+really2.32.4/debian/control and 6.0.1/glib2.0-2.33.12+really2.32.4/debian/control differ
Files 6.0.0/glib2.0-2.33.12+really2.32.4/debian/control.in and 6.0.1/glib2.0-2.33.12+really2.32.4/debian/control.in differ
Files 6.0.0/glib2.0-2.33.12+really2.32.4/debian/libglib2.0-0.postrm.in and 6.0.1/glib2.0-2.33.12+really2.32.4/debian/libglib2.0-0.postrm.in differ
Only in 6.0.1/gsasl-1.8.0/.pc: applied-patches
Only in 6.0.1/ifenslave-2.6-1.1.0/.pc: applied-patches
Only in 6.0.0: kernel-modules
Only in 6.0.1/ldb-1.1.15/.pc: applied-patches
Only in 6.0.1/libbsd-0.4.2/.pc: applied-patches
Only in 6.0.1/libcsv-3.0.2/.pc: applied-patches
Only in 6.0.1/libdatrie-0.2.5/.pc: applied-patches
Only in 6.0.1/libevent1.4-1.4.13-stable/.pc: applied-patches
Only in 6.0.1/libidn-1.25/.pc: applied-patches
Only in 6.0.1/libtasn1-3-2.13/.pc: applied-patches
Only in 6.0.1/libtext-charwidth-perl-0.04/.pc: applied-patches
Only in 6.0.1/libtext-iconv-perl-1.7/.pc: applied-patches
Only in 6.0.1/libthai-0.1.18/.pc: applied-patches
Only in 6.0.1/libunistring-0.9.3/.pc: applied-patches
Only in 6.0.1: linux-3.0.57
Only in 6.0.0: linux-uek-2.6.39.git
Only in 6.0.1/memtest86+-4.00: CVS
Only in 6.0.1/netatalk-3.0.2/.pc: applied-patches
Only in 6.0.1: nss-mdns-0.10
Only in 6.0.1/ntfs-3g-2012.1.15AR.5/.pc: applied-patches
Only in 6.0.0: openssl-1.0.1c
Only in 6.0.1: openssl-1.0.1e
Only in 6.0.1/proftpd-1.3.4b/debian: CVS
Only in 6.0.1/proftpd-1.3.4b/debian/patches: CVS
Only in 6.0.1/raidar-1.0.1/debian: .svn
Only in 6.0.1/raidar-1.0.1: .svn
Only in 6.0.1/sg3-utils-1.33/.pc: applied-patches
Files 6.0.0/sysvinit-2.88dsf/debian/changelog and 6.0.1/sysvinit-2.88dsf/debian/changelog differ
Files 6.0.0/sysvinit-2.88dsf/debian/control and 6.0.1/sysvinit-2.88dsf/debian/control differ
Files 6.0.0/sysvinit-2.88dsf/debian/initscripts.postinst and 6.0.1/sysvinit-2.88dsf/debian/initscripts.postinst differ
Files 6.0.0/sysvinit-2.88dsf/debian/po/de.po and 6.0.1/sysvinit-2.88dsf/debian/po/de.po differ
Files 6.0.0/sysvinit-2.88dsf/debian/postinst and 6.0.1/sysvinit-2.88dsf/debian/postinst differ
Files 6.0.0/sysvinit-2.88dsf/debian/src/initscripts/etc/init.d/mountall.sh and 6.0.1/sysvinit-2.88dsf/debian/src/initscripts/etc/init.d/mountall.sh differ
Files 6.0.0/sysvinit-2.88dsf/debian/src/initscripts/lib/init/mount-functions.sh and 6.0.1/sysvinit-2.88dsf/debian/src/initscripts/lib/init/mount-functions.sh differ
Files 6.0.0/sysvinit-2.88dsf/debian/src/initscripts/man/tmpfs.5 and 6.0.1/sysvinit-2.88dsf/debian/src/initscripts/man/tmpfs.5 differ
Only in 6.0.1/talloc-2.0.8/.pc: applied-patches
Only in 6.0.1/tevent-0.9.17/.pc: applied-patches
Only in 6.0.0: u-boot-2009.08
Files 6.0.0/udev-175/debian/changelog and 6.0.1/udev-175/debian/changelog differ
Files 6.0.0/udev-175/debian/rules and 6.0.1/udev-175/debian/rules differ
Files 6.0.0/udev-175/debian/udev.init and 6.0.1/udev-175/debian/udev.init differ
Files 6.0.0/udev-175/debian/udev.preinst and 6.0.1/udev-175/debian/udev.preinst differ
Only in 6.0.1/udev-175/debian: udev.udev-fallback-graphics.upstart
Only in 6.0.1/udev-175/debian: udev.udev-finish.upstart
Only in 6.0.1/udev-175/debian: udev.udevmonitor.upstart
Only in 6.0.1/udev-175/debian: udev.udevtrigger.upstart
Only in 6.0.1/udev-175/debian: udev.upstart
Files 6.0.0/zlib-1.2.7.dfsg/.pc/.quilt_series and 6.0.1/zlib-1.2.7.dfsg/.pc/.quilt_series differ
ProSupport for Business
