Progressed
Jul 11, 2011Aspirant
Help install Kolab on Netgear ReadyNAS Pro (ultra 4)
Hi I would like to have an Microsoft Exchange alternative on my Netgear. I was wondering if anyone knows kolab, and if so how to install it on my ReadyNAS. It seems Kolab is the ONLY alternative that is 100% free, and when its free... i love it :)
kolab: http://kolab.org/
Im kinda new on linux building packages, but i would like to make a package of this at the end with some help of the gurus here.
Thanks in advance!
Thanks in advance!
- WhoCares_Mentor
Progressed wrote: I know... but i was out of time and it was 3.30AM for the both of us neighbour :)
Usually a good time to contact me ;)Progressed wrote: Do you know if i could extend the internal memory easy? google hasnt much to say about this.
Heven't tried with the Ultra yet. Works fine on my Pro, though. So if you open your Ultra and check what specs the current RAM has I don't see why it shouldn't work using larger modules.
-Stefan - ProgressedAspirantDo you have some guides howto make addon-packages?
- WhoCares_MentorActually the general process is still the same as outline by Yoh-Dah's original post. The "magic" is in the install.sh which handles all the installation details and where you have to add your stuff.
-Stefan - ProgressedAspirantupdating the kernel now for installation of VMware... found compatible memory for upgrade.. going to buy 8 GB tommorow.
But seriously... if you can pull this off with kolab, I will donate extra money :) - kdannathAspirantI'll go inline with "Progressed", I will donate extra cash.
So what is the Status now? Any progres... - I have not had time to implement but, recommend trying with the Pro or Ultra series.
1. Setup VBox: Follow my guide post here for x86.
http://www.readynas.com/forum/viewtopic.php?f=35&t=26468&start=360
2. Install CentOS 6.2 or 6.3 as VM
3a. Follow "Quick HOWTO: Kolab 2.4 on CentOS 6.2"
http://kolab.org/howto/quick-howto-kolab-24-centos-62
or
3b. Follow "Quick HOWTO: Kolab 3.0 pre-alpha on CentOS 6.3"
http://kolab.org/blog/grote/2012/07/18/kolab-3.0-pre-alpha-release-and-installation
Looks like OwnCloud will be integrated into Kolab 3.0 by final release.
