BebeIsmo
May 05, 2016Aspirant
How do I properly configure svn on readynas 104
Hi, I have recently install subversion Apache on my readynas 104. Now I don't now how to configure it in order to manage my project ? Thanks you for your help S.T.
BebeIsmo
May 08, 2016Aspirant
Hello JennC,
thanks for your answers. Please can you send me again the URL that you provide in your message? In fact, it seems that there is a mistake in the link. Tanks you in advance!
best regards,
Sibiri T.
DaneA
May 08, 2016NETGEAR Employee Retired
Hi BebeIsmo,
On behalf of JennC, hope you could access this forum link below:
https://community.netgear.com/t5/Current-NETGEAR-and-Partners/subversion-configuration/td-p/860145
DaneA
NETGEAR Community Team
- StephenBMay 08, 2016Guru - Experienced User
DaneA wrote:
On behalf of JennC, hope you could access this forum link below...
I removed the extraneous space at the end of Jenn's link, so it should also work now.
- midgeJul 07, 2016Aspirant
Thanks for correcting the link... BUT
IS there any information anywhere on how to actually install SVN on an 104
I have "installed the APP" ... But then what
For the linked post it seem taht there are a few other things I need to enable (SSH) before I even start this activity
But I am not sure what
Regards
Andrew
- StephenBJul 07, 2016Guru - Experienced User
Not that I know of, but there's a lot of stuff in the forum. You can try using google with site:community.netgear.com - that works better than the forum search.
Perhaps someone else will chime in.
