Felson's avatar
Felson
Tutor
Mar 05, 2019
HOW-TO: Compile Custom Kernel Modules ReadyNASOS 6.9.X
I am going to do this example for the 'ppp' modules. If you need other modules, make adjustments as nessasary.
sudo apt update
sudo apt install libncurses5-dev
sudo apt install build-essential
sudo apt install bc
sudo apt install linux-image-extra
sudo depmod -a
sudo modprobe configs
os_version=`awk -F[=,] '{print $2}' /etc/os_version`
arch=`awk -F[=,] '{print $6}' /etc/os_version`
kernel_version=`uname -r`
cd ~
mkdir src cd src wget https://www.downloads.netgear.com/files/GPL/ReadyNASOS_V${os_version}_WW_src.zip mkdir ReadyNAS cd ReadyNAS 7z x ../ReadyNASOS_V${os_version}_WW_src.zip cd linux-${kernel_version%.*.*}-$arch zcat /proc/config.gz > .config make menuconfig
Nav to
Device Drivers-->Network device support
expand with an M "PPP (point-to-point protocol) support"
Mark wtih an M:
PPP MPPE compression (encryption)
PPP support for async serial ports
Mark with a * (space bar)
PPP filtering
exit/save
make prepare
make modules_prepare
make
cd ~/src
mkdir debian
cd debian
mkdir DEBIAN
mkdir -p lib/modules/${kernel_version}/kernel/lib
mkdir -p lib/modules/${kernel_version}/kernel/drivers/net/ppp
mkdir -p lib/modules/${kernel_version}/kernel/drivers/net/slip
cp ~/src/ReadyNAS/linux-${kernel_version%.*.*}-$arch/drivers/net/ppp/*.ko ~/src/debian/lib/modules/${kernel_version}/kernel/drivers/net/ppp/
cp ~/src/ReadyNAS/linux-${kernel_version%.*.*}-$arch/drivers/net/slip/*.ko ~/src/debian/lib/modules/${kernel_version}/kernel/drivers/net/slip/
cp ~/src/ReadyNAS/linux-${kernel_version%.*.*}-$arch/lib/crc-ccitt.ko ~/src/debian/lib/modules/${kernel_version}/kernel/lib/
printf "Package: ppp-kernel-modules\nVersion: $os_version\nSection: custom\nPriority: optional\nArchitecture: all\nEssential: no\nInstalled-Size: $(du --max-depth=0 | awk '{print $1}')\nMaintainer: Me\nDescription: Custom modules\n" > DEBIAN/control
cd ..
dpkg-deb --build debian
mv debian.deb ppp-kernel-modules.deb
sudo dpkg -i ppp-kernel-modules.deb
sudo depmod -a
run the following to see if it worked...
sudo modprobe ppp_generic
If it returned no errors you are golden.
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hi Felson , thanks for posting this. Great to know, that this is possible. Kind regards
ProSupport for Business
