AlexSLTay
Jan 07, 2020Aspirant
How to disable readycloud
I have accidentally turned on ReadyCloud sync with my office PC and that effectively chewed up all my Office PC SSD storage. How do I pause or stop the sync so I can clear HDD space on my office PC? ...
- Jan 07, 2020
Welcome to the Community!
Make sure that you have backup first of what you intend to delete then turn off ReadyCloud on your NAS. It is under the Cloud tab of the Web GUI, you just need to toggle the On/Off Slider.
If you don't want to stop the service of your ReadyCloud then just click on the Folder that is syncing on the ReadyCloud client app and stop/pause the sync. Alternatively, uninstalling the app should do the job as well,.
HTH
Regards
Marc_V
Jan 07, 2020NETGEAR Employee Retired
HTH
Regards
AlexSLTay
Thanks Marc, this works!
