devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
mdgm-ntgr
Nov 29, 2009NETGEAR Employee Retired
WhoCares? wrote:
mdgm wrote: Hopefully a firmware re-install would get the NAS working again.
That's one of the problems because most likely it wouldn't.
-Stefan
Ok. So yeah SSH installed would be a must. Also a simple script to restore default conf files. That could be started by e.g.
/c/script.sh
or whatever you want to call it. That should fix a problem if something goes drastically wrong (I think). If it doesn't then perhaps a script (with files from a working system on the same firmware version) may need to be downloaded.
