devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
montrose_it
Apr 11, 2011Aspirant
Hello All,
i opening this one up again! i'll try and keep my post short.
my employer has a NV+ which i have been allowed to host a website on for a little while. I have recently added a file upload section to the site, however have had trouble with the upload file size. i have edited this as per instructions found in the forum but to no avail, max file size is still about 1.3 mb. I understood that the problem probably lay in the fact i was using SP's PHP which there are some issues with. Due to the fact that this doesn't uninstall properly, I purchased a DUO off a friend with a view to starting on a clean footing.
Heres what I have done:
Installed PHP 5.2.13 viewtopic.php?f=47&t=35880#p199466
Set up a share called 'sites'
Set up a sub folder as my website domain - e.g. 'mydomain'
edited Virtual.conf as above
added my-virtual.conf
this rendered Frontview and http access not avaliable so i changed Virtual.conf back again and removed my-virtual.conf to get back into the setup
with the PHP addon above, i should be able to upload 8mb - it still fails at over 1.5mb - what is the problem?
i can access my web pages ok but the nas asks me to log in every time. since 'sites' is set as read-only with no user authentication, i can't understand this.
i don't actually want to host 2 websites but rather avoid having to have 'sites' after the domain before the page name . e.g. http://www.mydomain.com/sites/index.html
from the post i understand it is possible to do this - i have it nearly working on the NV+ apart from the fact is likewise asks you to login.
i will be grateful for all suggestions and help
-Rick
-Rick
