devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
montrose_it
Apr 11, 2011Aspirant
right - issue(s) solved. website now up and running - index page only - i have some major editing to do. :(
just fyi i've used a configuration very similar to that posted right at the start of this howto... will post the final code tomorrow when i can get back in the box. (bed now!)
just off hand does anyone know if you can edit the timeout time of a webpage...? as i mentioned i have this upload page which works fine on files up to about 2.8mb or so but the webpage times out on larger files before the script can actually upload them. therefore you don't get a error message to same unsupported file type or too large as neither are true.
when i had Sp's php i edited PHP.ini so am aware how to do this if the answer is there.
thanks in anticipation
edit: sorted the upload issue by editing some files in php.ini can now upload any size i want :)
