devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys,
For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it.
1. Backup all the .conf files in /etc/frontview/apache
2. Backup all the .conf files in /etc/frontview/apache - so you can restore the originals if you screw something up !!!
3. Edit /etc/frontview/apache/Virtual.conf
Original file
Modified file
4. Create a new my-virtual.conf file in /etc/frontview/apache/addons, this way it will be auto loaded without modifying any other files. The example below has definitions for two websites....add/remove as required.
my-virtual.conf
5. shutdown apache, killall apache-ssl
6. restart apache, apache-ssl -f /etc/frontview/apache/httpd.conf
7. All done :D
CAVEATS
1. Toggling the state of HTTP within Frontview rewrites Virtual.conf so the above changes will be lost.
ReadyNAS Team
1. It would be nice if the above changes could be made to the format of /etc/frontview/apache/Virtual.conf, so that changes aren't overwritten
2. I currently have to add the Location element to undo a global definition within httpd.conf. It would be awesome if this was removed from httpd.conf and added to Virtual.conf as...
Cheers,
David
Original file
<VirtualHost _default_:80>
SSLEngine off
RewriteEngine on
RewriteRule ^/admin/(.*)$ https://%{SERVER_NAME}/admin/$1 [R,L]
</VirtualHost>
Modified file
NameVirtualHost *:80
<VirtualHost *:80>
SSLEngine off
RewriteEngine on
</VirtualHost>
my-virtual.conf
<VirtualHost *:80>
ServerName www.example.com
DocumentRoot /path/to/example.com
<Directory /path/to/example.com>
Options Indexes
Order allow,deny
Allow from all
</Directory>
<Location /index.html>
SetHandler none
Order Allow,Deny
Allow from all
</Location>
SSLEngine off
</VirtualHost>
<VirtualHost *:80>
ServerName www.domain.net
DocumentRoot /path/to/domain.net
<Directory /path/to/domain.net>
Options Indexes
Order allow,deny
Allow from all
</Directory>
SetHandler none
Order Allow,Deny
Allow from all
</Location>
SSLEngine off
</VirtualHost>
7. All done :D
CAVEATS
ReadyNAS Team
<VirtualHost *:80>
SetHandler server-status
Order Deny,Allow
Deny from all
</Location>
SSLEngine off
RewriteEngine on
</VirtualHost>
Cheers,
David
- WhoCares_MentorWhat does the error.log of Apache say about this?
-Stefan - stinhamboAspirant[Mon Feb 21 09:24:45 2011] [error] [client 192.168.0.192] Options FollowSymLinks or SymLinksIfOwnerMatch is off which implies that RewriteRule directive is forbidden: /c/sites/mysite/
- WhoCares_MentorThere's something wrong with your vhost config. To debug this using the forum isn't going to work I think. If you're interested I can have a look using TeamViewer (www.teamviewer.com). Just PM me with the login info if you like.
-Stefan - stinhamboAspirantThanks Stefan!
I'll let you know when I've got it all set up. - WhoCares_MentorDon't worry too much. I'm not at all interested in what you're going to serve and if possible I won't even look there ;)
-Stefan - stinhamboAspirantI trust you :)
We need a definitive web hosting server setup guide as opposed to bits and pieces scattered around the forums.
In fact I'm surprised ReadyNas don't ship one as standard like QNAP do. It can always be updated if it doesn't suit. - WhoCares_MentorWait for me to finish my add-on ;)
-Stefan - stinhamboAspirantOoh really? Got an ETA for that? Really need to start developing sites on this box.
PS. PHP 5.3.x would be a bonus! - stinhamboAspirantSilence... PM me with details?
- WhoCares_MentorJust overlooked the message. No ETA right now, and I'm quite reluctant to support PHP 5.3.x (although I have one ready, actually) because PHP 5.3.x right now causes more trouble than it does good. What ReadyNAS do you have? Just skimmed through the messages but didn't see any mention (may well be my eyes getting tired).
-Stefan
