dmacleo
Sep 05, 2015Guide
how to manually remove subsonic on readynas 314
for some reason subsonic stopped working, admin page not working, and I need to remove it. when removing from apps page it hags a bit then refreshes and app still shows installed. will deleting (or ...
mdgm-ntgr
Sep 06, 2015NETGEAR Employee Retired
Are you comfortable with the implications of enabling SSH and with using that?
