dmacleo
Sep 05, 2015Guide
how to manually remove subsonic on readynas 314
for some reason subsonic stopped working, admin page not working, and I need to remove it. when removing from apps page it hags a bit then refreshes and app still shows installed. will deleting (or ...
mdgm-ntgr
Sep 06, 2015NETGEAR Employee Retired
Are you comfortable with the implications of enabling SSH and with using that?
dmacleo
Sep 07, 2015Guide
yeah am ok using ssh I just was not able to see what name it used during installation.
- dmacleoSep 07, 2015Guide
possibly related, when I install an app I get error msg sayign it cannot be installed yet app does get installed and works fine.
- JennCSep 08, 2015NETGEAR Employee Retired
Hello dmacleo,
Do you get the same problem using a different web browser? What's the current FW version?
And does other app work when installed?
- dmacleoSep 08, 2015Guide
browser does not matter and the readynas 314 is firmware 6.2.4 and I have already done OS reinstall.
this oddity on installing started hapening when I tried to (incorrectly I guess) use ssh to install then remove subsonic.
as far as I can tell all apps work fine so its not critical.
think when my rma'd 104 comes in tomorrow I will migrate all files to it and do factory reset unless you know of some trick I can try.
where I am comfortable with ssh I am willing to try anything, if I am right doing a correct subsonic install and remove from ssh MAY correct this issue.
