kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
drey
Dec 03, 2009Aspirant
kraney wrote:
Finally, you'll need to build the PPP kernel modules. This howto assumes you'll be building the kernel modules directly on the NAS device. You can also cross-compile on a different box, but I'll leave that explanation to other guides.
- Download the Linux kernel posted at http://www.readynas.com/gpl
- run
apt-get install libncurses5-dev(needed to run menuconfig when setting up the kernel)- cd to the linux kernel directory, and run
cp arch/padre/defconfig .config- There is a hardcoded cross-compile setup in the kernel build, which needs to be fixed. Edit arch/padre/Makefile, and replace the line that starts with "CROSS_COMPILE" with one like this
CROSS_COMPILE ?=- run
make menuconfig- Navigate to the "Network Device Support -> PPP (point-to-point protocol support)" page
- enable "PPP" by pressing "M" to mark it as a module
- also enable MPPE compression and async serial support.
- enable ppp filtering by pressing the space bar (it isn't a module, so 'M' doesn't work.)
- save the configuration and run
make modules
cp drivers/net/{ppp_async,ppp_mppe,ppp_generic,slhc}.ko /lib/modules/2.6.17.8ReadyNAS/kernel/drivers/net/
mkdir /lib/modules/2.6.17.8ReadyNAS/kernel/crypto
cp crypto/{sha1,arc4}.ko /lib/modules/2.6.17.8ReadyNAS/kernel/crypto/
depmod -a
At this point, you should be able to connect from your VPN client, using the username and password you added to /etc/ppp/chap-secrets. The kernel will automatically load the new modules when they're needed.
If you run into trouble, check /var/log/syslog on the ReadyNAS for error messages.
You lost me there on Step 3. Where is arch/padre/Makefile?
