kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
mfe_
Dec 02, 2010Tutor
hello,
i did the descried steps in the first post. compiling worked also fine. but when im trying to login via windows pptp client i get this error on the readynas:
Is this issuse a config failure?
greetings
fes-a120d19nas:~# tail /var/log/syslog
Dec 2 23:36:35 fes-a120d19nas pppd[6341]: rcvd [LCP ConfReq id=0x8 <mru 1400> <magic 0x6e8c2f47> <pcomp> <accomp> <callback CBCP>]
Dec 2 23:36:35 fes-a120d19nas pppd[6341]: sent [LCP ConfRej id=0x8 <callback CBCP>]
Dec 2 23:36:37 fes-a120d19nas pppd[6341]: LCP: timeout sending Config-Requests
Dec 2 23:36:37 fes-a120d19nas pppd[6341]: Connection terminated.
Dec 2 23:36:37 fes-a120d19nas pppd[6341]: using channel 14
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: Using interface ppp0
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: Connect: ppp0 <--> /dev/pts/1
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: sent [LCP ConfReq id=0x2 <asyncmap 0x0> <auth chap MS-v2> <magic 0x46330144> <pcomp> <accomp>]
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: sent [LCP TermReq id=0x3]
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: tcflush failed: Bad file descriptor
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: tcsetattr: Invalid argument (line 1010)
Dec 2 23:36:38 fes-a120d19nas pppd[6341]: Exit.
Dec 2 23:36:38 fes-a120d19nas pptpd[6340]: GRE: read(fd=4,buffer=250c8,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Dec 2 23:36:38 fes-a120d19nas pptpd[6340]: CTRL: PTY read or GRE write failed (pty,gre)=(4,5)
Dec 2 23:36:38 fes-a120d19nas pptpd[6340]: CTRL: Reaping child PPP[6341]
Dec 2 23:36:38 fes-a120d19nas pptpd[6340]: CTRL: Client 46.124.23.100 control connection finished
Dec 2 23:36:38 fes-a120d19nas pptpd[6340]: CTRL: Couldn't write packet to client.
greetings
