kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
mfe_
Mar 16, 2011Tutor
Hello,
after the new firmeware update the syslog tells me that the kernel got no ppptp support.
Trying to compile the moduls by myself isnt working for me because of:
Got some one the compiled moduls for 2.6.17.2.6.17.14ReadyNAS?
[EDIT]
I found out, that i can use the moduls from the firmware 2.6.17.2.6.17.8 also in the Firmware 2.6.17.2.6.17.14. So i just copied them to the right directory.
The compiled Moduls can be found here: http://cid-a7082d0a1081e2f0.office.live ... odules.zip
apt-get install build-essential -f
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev-sparc64 but it is not going to be installed
Depends: dpkg-dev (>= 1.4.1.19) but it is not going to be installed
E: Broken packages
[EDIT]
