kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
indomiti
Apr 06, 2011Aspirant
Im trying to build the kernel modules for ppp
Im running firmware 4.2.16 on Ultra 4.
I downloaded the kernel from here: http://www.readynas.com/gpl
Copy the URL for 4.2.15 then changed it into 4.2.16 so the download is:
http://www.readynas.com/download/GPL/RN ... WW_src.zip
unzip it and then run "make oldconfig" in the linux-2.6.37.5/ directory
But there is no .config or .config.old file available, what should i do? am i doing something wrong?
