kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
WhoCares_
Apr 07, 2011Mentor
If you look into arch/x86/configs you'll find defconfig.smp (64bit) and defconfig.up (32bit). Copy to the appropriate place (kernel-dir/.config) and then run "make oldconfig".
However, it seems that the GPL archive doesn't contain the latest kernel sources. Should work for building kernel modules, though.
-Stefan
-Stefan
