kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
WhoCares_
Apr 07, 2011Mentor
No, that's fine. As you can see from the uname output, you have an SMP kernel, so defconfig.smp should be the right one for you. So something else must have gone wrong while building the kernel and the modules. I suggest you do a "make mrproper" and start from scratch.
-Stefan
-Stefan
