kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
mfe_
Apr 14, 2011Tutor
indomiti wrote: Thank you guys! I did it all over again and this time it worked, the only thing i changed was that i did a "make all" before make menuconfig.
Everything seems to be working :)
Why you didnt take the compiled modules? Didnt work the compiled moduls?
edit:
ah okay i see you use a readynas ultra 4.
