kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
mfe_
Jun 22, 2011Tutor
efalsken wrote:
On Windows, it's called "Use default gateway" and is in the network, TCP/IP settings.
Hi, thanks for your reply. I unchecked "Use default gateway" in the TCP/IP settings, because i will lose the internet connection when I'm connected to the vpn.
Have i to add a route on the nas that i can use the internet when im using the vpn connection?
greetings
