kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
kraney
Feb 02, 2012Aspirant
You will definitely need curses to run menuconfig. The error you get when installing curses would be more useful for diagnosing what's going on.
You could potentially use "make config" rather than menuconfig to avoid the need for curses, but I recommend against it because it does the job as a long, tedious series of questions that's easy to screw up.
apt-get install libncurses5-dev
