kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
inertia
May 13, 2012Aspirant
Also trying to achieve the same thing on a custom lacie machine. Have got everything working except uPNP discovery.
Annoying, the Android music apps I use don't allow you to manually specify the server string so I also have to rely on discovery working.
Have tried with bcrelay, in the same subnet etc. Just cannot make it work.
Next step is to try openVpn as I heard this solves the problem.
