kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
wizzard
Jul 13, 2012Aspirant
What ports do I need to farward in my router?
Edit: probably not port errors.
On Iphone I get this error
VPN Connection
You are discionected by the communication device. *Try reconnecting. If the problem continues, verfy your settings.
Log from readynas
VPN Connection
Log from readynas
Jul 13 05:52:53 readynas pptpd[1527]: GRE: read(fd=6,buffer=8058640,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Jul 13 05:52:53 readynas pptpd[1527]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
Jul 13 05:52:53 readynas pptpd[1527]: CTRL: Reaping child PPP[1528]
Jul 13 05:52:53 readynas pptpd[1527]: CTRL: Client 109.58.145.xxx control connection finished
Jul 13 05:52:53 readynas kernel: ppp_async: Unknown symbol crc_ccitt_table (err 0)
Jul 13 05:53:02 readynas pptpd[1536]: CTRL: Client 109.58.145.xxx1 control connection started
Jul 13 05:53:03 readynas pptpd[1536]: CTRL: Starting call (launching pppd, opening GRE)
Jul 13 05:53:03 readynas pppd[1537]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Jul 13 05:53:03 readynas pppd[1537]: pppd 2.4.4 started by root, uid 0
Jul 13 05:53:03 readynas kernel: ppp_async: Unknown symbol crc_ccitt_table (err 0)
Jul 13 05:53:03 readynas modprobe: FATAL: Error inserting ppp_async (/lib/modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/net/ppp_async.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Jul 13 05:53:03 readynas pppd[1537]: Couldn't set tty to PPP discipline: Invalid argument
Jul 13 05:53:03 readynas pppd[1537]: Exit.
Jul 13 05:53:03 readynas pptpd[1536]: GRE: read(fd=6,buffer=8058640,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Jul 13 05:53:03 readynas pptpd[1536]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
Jul 13 05:53:03 readynas pptpd[1536]: CTRL: Reaping child PPP[1537]
Jul 13 05:53:03 readynas pptpd[1536]: CTRL: Client 109.58.145.xxx control connection finished
Jul 13 06:11:39 readynas udhcpc[2427]: Sending renew...
Jul 13 06:11:39 readynas udhcpc[2427]: Lease of 192.168.1.106 obtained, lease time 3600
Jul 13 06:25:06 readynas syslogd 1.4.1#18: restart.
Jul 13 06:41:39 readynas udhcpc[2427]: Sending renew...
Jul 13 06:41:39 readynas udhcpc[2427]: Lease of 192.168.1.106 obtained, lease time 3600
Jul 13 07:11:40 readynas udhcpc[2427]: Sending renew...
Jul 13 07:11:40 readynas udhcpc[2427]: Lease of 192.168.1.106 obtained, lease time 3600
Jul 13 07:15:23 readynas pptpd[1961]: CTRL: Client 109.58.145.xxx control connection started
Jul 13 07:15:25 readynas pptpd[1961]: CTRL: Starting call (launching pppd, opening GRE)
Jul 13 07:15:25 readynas pppd[1962]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Jul 13 07:15:25 readynas pppd[1962]: pppd 2.4.4 started by root, uid 0
Jul 13 07:15:25 readynas modprobe: FATAL: Error inserting ppp_async (/lib/modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/net/ppp_async.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Jul 13 07:15:25 readynas pppd[1962]: Couldn't set tty to PPP discipline: Invalid argument
Jul 13 07:15:25 readynas pppd[1962]: Exit.
Jul 13 07:15:25 readynas pptpd[1961]: GRE: read(fd=6,buffer=8058640,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Jul 13 07:15:25 readynas pptpd[1961]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
Jul 13 07:15:25 readynas pptpd[1961]: CTRL: Reaping child PPP[1962]
Jul 13 07:15:25 readynas pptpd[1961]: CTRL: Client 109.58.145.xxx control connection finished
Jul 13 07:15:25 readynas kernel: ppp_async: Unknown symbol crc_ccitt_table (err 0)
Jul 13 07:23:06 readynas pptpd[1977]: CTRL: Client 109.58.145.xxx control connection started
Jul 13 07:23:07 readynas pptpd[1977]: CTRL: Starting call (launching pppd, opening GRE)
Jul 13 07:23:07 readynas pppd[1978]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Jul 13 07:23:07 readynas pppd[1978]: pppd 2.4.4 started by root, uid 0
Jul 13 07:23:07 readynas modprobe: FATAL: Error inserting ppp_async (/lib/modules/2.6.37.6.RNx86_64.2.4/kernel/drivers/net/ppp_async.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Jul 13 07:23:07 readynas pppd[1978]: Couldn't set tty to PPP discipline: Invalid argument
Jul 13 07:23:07 readynas pppd[1978]: Exit.
Jul 13 07:23:07 readynas pptpd[1977]: GRE: read(fd=6,buffer=8058640,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
Jul 13 07:23:07 readynas pptpd[1977]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
Jul 13 07:23:07 readynas pptpd[1977]: CTRL: Reaping child PPP[1978]
Jul 13 07:23:07 readynas pptpd[1977]: CTRL: Client 109.58.145.xxx control connection finished
Jul 13 07:23:07 readynas kernel: ppp_async: Unknown symbol crc_ccitt_table (err 0)
