kraney
Sep 11, 2009Aspirant
HOWTO: PPtP VPN
This howto will list the steps necessary to set up a pptp server on a ReadyNAS Duo. PPtP makes a nice choice, because OSX natively supports connecting to PPtP VPNs. I think windows does also, but don'...
thequarter84
Aug 15, 2013Aspirant
Hi guys, I follow your suggests and I was lucky... a make without an error :)
I can't still connect to the server
This is modprobe result:
is ppp_async my problem? what did I wrong?
thanks
Paolo
root@LEONAS:~# modprobe ppp_generic
WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
WARNING: All config files need .conf: /etc/modprobe.d/display_class, it will be ignored in a future release.
WARNING: All config files need .conf: /etc/modprobe.d/pnp-hotplug, it will be ignored in a future release.
root@LEONAS:~# tail -f /var/log/syslog
Aug 15 17:31:50 LEONAS avahi-daemon[3987]: Registering new address record for 10.1.3.251 on eth0.IPv4.
Aug 15 17:31:50 LEONAS avahi-daemon[3987]: Registering HINFO record with values 'ARMV5TEL'/'LINUX'.
Aug 15 17:31:50 LEONAS avahi-daemon[3987]: Server startup complete. Host name is LEONAS.local. Local service cookie is 125115100.
Aug 15 17:31:51 LEONAS avahi-daemon[3987]: Service "ReadyNAS Discovery [LEONAS]" (/services/readynas.service) successfully established.
Aug 15 17:31:51 LEONAS avahi-daemon[3987]: Service "FrontView on LEONAS" (/services/frontview.service) successfully established.
Aug 15 17:31:51 LEONAS avahi-daemon[3987]: Service "LEONAS (CIFS)" (/services/cifs.service) successfully established.
Aug 15 17:31:51 LEONAS avahi-daemon[3987]: Service "LEONAS (AFP)" (/services/afp.service) successfully established.
Aug 15 17:32:58 LEONAS kernel: program smartctl.org is using a deprecated SCSI ioctl, please convert it to SG_IO
Aug 15 17:32:58 LEONAS last message repeated 12 times
Aug 15 17:34:45 LEONAS kernel: PPP generic driver version 2.4.2
Aug 15 17:35:18 LEONAS pptpd[4111]: CTRL: Client 176.244.210.55 control connection started
Aug 15 17:35:19 LEONAS pptpd[4111]: CTRL: Starting call (launching pppd, opening GRE)
Aug 15 17:35:19 LEONAS pppd[4118]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Aug 15 17:35:19 LEONAS pppd[4118]: pppd 2.4.5 started by root, uid 0
Aug 15 17:35:19 LEONAS kernel: ppp_async: Unknown symbol crc_ccitt_table
Aug 15 17:35:19 LEONAS modprobe: FATAL: Error inserting ppp_async (/lib/modules/2.6.31.8.duov2/kernel/drivers/ppp_asyter (see dmesg)
Aug 15 17:35:19 LEONAS pppd[4118]: Couldn't set tty to PPP discipline: Invalid argument
Aug 15 17:35:19 LEONAS pppd[4118]: Exit.
Aug 15 17:35:19 LEONAS pptpd[4111]: GRE: read(fd=7,buffer=1bce8,len=8196) from PTY failed: status = -1 error = Input/ion of pppd, check option syntax and pppd logs
Aug 15 17:35:19 LEONAS pptpd[4111]: CTRL: PTY read or GRE write failed (pty,gre)=(7,8)
Aug 15 17:35:19 LEONAS pptpd[4111]: CTRL: Reaping child PPP[4118]
Aug 15 17:35:19 LEONAS pptpd[4111]: CTRL: Client 176.244.210.55 control connection finished
thanks
Paolo
