djbii
Sep 09, 2016Aspirant
Installed subsonic 6 but it won't autostart
Howdy, I have a readynas 314 running firmware 6.5.1 (the latest) and I installed subsonic v 6 via the [upload] button on the [apps] tab on the admin page. I got the app from https://community.net...
JennC
Sep 10, 2016NETGEAR Employee Retired
Hello djbii,
It may be best to check this with the developer, super_poussin.
Welcome to the community!
- djbiiSep 11, 2016AspirantThanks JennC, I'll give it a go :-)
- BrianL2Sep 12, 2016NETGEAR Employee Retired
Hello djbii,
If the issue is resolved, click the "Accept as Solution" button in one of the responses that you received. Just post back or update this thread if the issue still persists or if you have further questions.
Kind regards,
BrianL
NETGEAR Community Team- djbiiSep 13, 2016AspirantI thought I had the answer but it turns out I didn't. There was no systemd service set up for it so I ran: systemctl enable application.service to enable the service. The service then auto started on boot and I was happy but then after a certain amount of time it shutdown again. It does this after every reboot. I have logs if anyone wants to look at them.
