DPeach
Apr 13, 2019Tutor
iPhone ReadyCLOUD Moble Client Network error occured
I am attempting to login to ReadyCloud with Netgear through the app (version 2.0.4) on my iOS (iPhone X iOS v12.2) but unless i turn on the wifi I only get a prompt that states Network Error Occured ...
- May 13, 2019
In the settings of your iPhone under "Mobile Network" (I guess that name, as I only have a German version) you can select which app is allowed to use mobile network. Did you check that?
JohnCM_S
Apr 19, 2019NETGEAR Employee Retired
Hi DPeach,
I understand that you are not able to login to ReadyCLOUD using the app on your iOS when WiFi is disconnected. This is actually normal since you need Internet Connection to be able to login to ReadyCLOUD.
