DPeach
Apr 13, 2019Tutor
iPhone ReadyCLOUD Moble Client Network error occured
I am attempting to login to ReadyCloud with Netgear through the app (version 2.0.4) on my iOS (iPhone X iOS v12.2) but unless i turn on the wifi I only get a prompt that states Network Error Occured ...
- May 13, 2019
In the settings of your iPhone under "Mobile Network" (I guess that name, as I only have a German version) you can select which app is allowed to use mobile network. Did you check that?
DPeach
Apr 19, 2019Tutor
Thank you. I thought I was doing something wrong. So if I understand you correctly I cannot access ReadyCLOUD over cellular?
JohnCM_S
Apr 19, 2019NETGEAR Employee Retired
Hi DPeach,
You should still be able to access the ReadyCLOUD if you are using mobile data. Let us try isolating the issue first. Can you access ReadyCLOUD through the web portal (readycloud.netgear.com) when the iPhone is connected via mobile data?
