DPeach
Apr 13, 2019Tutor
iPhone ReadyCLOUD Moble Client Network error occured
I am attempting to login to ReadyCloud with Netgear through the app (version 2.0.4) on my iOS (iPhone X iOS v12.2) but unless i turn on the wifi I only get a prompt that states Network Error Occured ...
- May 13, 2019
In the settings of your iPhone under "Mobile Network" (I guess that name, as I only have a German version) you can select which app is allowed to use mobile network. Did you check that?
tom1stein
May 13, 2019Initiate
- DPeachMay 16, 2019TutorYou, my friend, are a genius!! And I feel so retarded!! Thanks you! Sometimes it’s the obvious solution.
