roger_roger
Dec 11, 2009Tutor
is there a Java VM for NV+
Is it possible to install java on the readynas NV+ I have a simple text based java application that grabs data from a webpage and loads to mysql on the readynas. It would be nice if I could schedu...
roger_roger
Jan 04, 2010Tutor
Nas-R wrote: I was able to manage to install Java 6 on the pro.
(not sure if the NV+ CPU/memory is able to handle it.)
Anyhow here are the steps...
In your /etc/apt/sources.list adddeb http://us.archive.ubuntu.com/ubuntu dapper main restricted
deb http://us.archive.ubuntu.com/ubuntu dapper universe multiverse
then I did;apt-get update
apt-get install sun-java6-jdk
After this the rest of the process will display a dialog that will require you to accept the license agreement. When you do, the rest of the setup will happen on its own.
change temporary indpkg-reconfigure debconfNonInteractive to Readline, once completed change it back
When you're on the command prompt typejavac -versionorjava -version
You should be good to go! :D
Sorry for delay in the response, just come back from the year end vacation.
First of all thanks for the reply.
My NV+ is vanilla out of the box installation so the commands above don't appear on my box...... :(
How scarey is the process of changing it to handle this? I have plenty experience with linux , but there's alot of data on the NV+ that is not worth losing.
