roger_roger
Dec 11, 2009Tutor
is there a Java VM for NV+
Is it possible to install java on the readynas NV+ I have a simple text based java application that grabs data from a webpage and loads to mysql on the readynas. It would be nice if I could schedu...
dbott67
Jan 04, 2010Guide
You would need to install the EnableRootSSH add-on in order to gain root access, followed by the APT add-on.
Both add-ons can be found here under the SHELL ACCESS PATCHES: http://www.readynas.com/?page_id=617
You do not need the ToggleSSH add-on (it will disable SSH access if you run it).
As for whether or not it will work, there are others that have also indicated that the CPU on the NV/NV+/Duo is not powerful enough.
