roger_roger
Dec 11, 2009Tutor
is there a Java VM for NV+
Is it possible to install java on the readynas NV+ I have a simple text based java application that grabs data from a webpage and loads to mysql on the readynas. It would be nice if I could schedu...
berkut1
Oct 11, 2010Tutor
Nas-R wrote: Sorry for some delay;
It seems that Sun has moved their SUN-6-SDK to another location, just add this into your sources.listdeb http://archive.canonical.com/ lucid partnerand try again.
To verify:Crius:/etc/apt# java -version
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) Client VM (build 16.3-b01, mixed mode, sharing)
Crius:/etc/apt# javac -version
javac 1.6.0_20
Crius:/etc/apt#
Thanks, that did the trick!
