roger_roger
Dec 11, 2009Tutor
is there a Java VM for NV+
Is it possible to install java on the readynas NV+ I have a simple text based java application that grabs data from a webpage and loads to mysql on the readynas. It would be nice if I could schedu...
kiwi1969
Dec 07, 2011Aspirant
I was wondering if anyone has tried compiling IcedTea for NV+
It is meant to be totally open source so should be possible ?
Even if it is using zero interpreter (i.e. no JIT), it would be better than nothing.
It seems that there are instructions for Sparc on Gento Linux which may be useful here.
Their method requires someone getting Portage scripts working on Debian Linux first.
Here are some links if someone wants to get things started (It is probably beyond my ability, but I think I will give things a go using the Sparc QEMU image)
http://en.gentoo-wiki.com/wiki/Java_on_SPARC
Info about trying to get Portage on other linux systems is here : http://forums.gentoo.org/viewtopic.php?t=125553
