roger_roger
Dec 11, 2009Tutor
is there a Java VM for NV+
Is it possible to install java on the readynas NV+ I have a simple text based java application that grabs data from a webpage and loads to mysql on the readynas. It would be nice if I could schedu...
Scouser
Dec 08, 2011Aspirant
Dont know about the NV+ but on my Pro 6, the following worked for me
1. Add "deb http://archive.debian.org/debian-backports etch-backports main non-free" to /etc/apt/sources.list
2. type apt-get update
3. type dpkg-reconfigure debconf
Select Option 1 Dialog
Select Option 3 Medium
4. type apt-get install sun-java6-jre
