SJMarty
Aug 02, 2015Aspirant
iStat Installation on Sparc
I have an NV and an NV+ and I'm running NAS Utils on my Android phone. I'd like to install iStat to view performance but can't seem to find the installation steps. The app points to this URL but I ...
Aug 02, 2015Guru - Experienced User
Not sure why you are seeing the access denied, but here is a partial copy of the url you can't reach:
Istat (04/23/2010)
- Changes in 1.5:
- based on Istatd 0.5.7
- Temperature and fan support with lm_sensors (not for Readynas)
- Fix: Memory meterics incorrect in Linux (cached).
- Fix: Do not create PID file if it's not specified in config.
- Fix: Removed unneccesary linkage to libld.
- Fix: Reverted load avg. probe for procfs.
- Fix: Segfault when reading cache with more than one client.
- Fix: PID file contained the mother PID when -d
- now support bonjour (thanks chirpa)
