kevcompton
Sep 07, 2017Apprentice
Java 8 on ReadyNAS 516
Hi, Need to install Java 8 JDK so I can get the latest version of OpenHab running. Anybody know how to do it? Thanks.
Marty_M
Sep 14, 2017NETGEAR Employee Retired
Hello kevcompton,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
OOM-9
Sep 14, 2017NETGEAR Expert
It looks like this thread would be helpful to follow:
https://community.netgear.com/t5/Using-your-ReadyNAS/How-to-install-Java-8-JDK-on-RN312/td-p/1369477
The ReadyNAS on the backend is based on Debian (Jessie) and you would be able to perform similar tasks on the backend to get some of these packages installed.
