fmhemmer
Sep 02, 2017Follower
Large first backup to ReadyNAS Vault
Trying to use ReadyNAS Vault on RN316. Firmware up to date; Vault enabled; Setting under Manage Backups seem correct BUT... Not sure about "Includes" configuration. Include Folders field shows the...
ReadyNAS-Vault
Sep 05, 2017Apprentice
Hi fmhemmer,
Sorry to hear about the challenge you are having to get started with the ReadyNAS Vault.
By default, the "includes" tab should pre-populate the drop-down menu of the "Folder:" selection option with the paths of each of the network shares on the NAS. You can use the drop-down to select a share. If you would like to backup a specific folder within the share only, you will need to write in the remainder of the path (we are working on an option to allow full browsing).
Since it looks lke the folder in question (/data/ADMIN) is a share, it should present in the drop-down for easy selection. If that is not that case, we would like to schedule a live screenshare support session with one of our technical specialists. Please send us a Private Message with the email associated with your account, and we will contact you directly to set up a time (also, we can research your account ahead of the session, so we can better and more efficiently support you).
In the meantime, for any other users curious about this question, there is an FAQ here on the subject:
http://support.readynasvault.com/hc/en-us/articles/208283106-Web-Portal-Creating-Modifying-Backups
Thanks,
ReadyNAS Vault Team
