Hyperbit
Oct 31, 2012Aspirant
LIBC6 update
i try to install PyCrypto but i get some errors Preparing to replace python-crypto 2.6-2 (using python-crypto_2.6-2_sparc.deb) ... Unpacking replacement python-crypto ... dpkg: dependency problems...
Etz
Dont do it, as it basically breaks ReadyNAS OS and you have to do factory default, (which will wipe your data) after that, to restore it into working order.
If you use forum search there are lots of topics about Libc6 update and sideeffects of that.
For example:
viewtopic.php?f=35&t=51949
viewtopic.php?f=65&t=43605
For example:
