Hyperbit
Oct 31, 2012Aspirant
LIBC6 update
i try to install PyCrypto but i get some errors Preparing to replace python-crypto 2.6-2 (using python-crypto_2.6-2_sparc.deb) ... Unpacking replacement python-crypto ... dpkg: dependency problems...
Etz
Nov 01, 2012Aspirant
Hyperbit wrote: I Got this startupscript inside of init.d , where can i call it for startup ??
I trydupdate-rc.d pyload defaultswithout success
Did you reboot the unit afterwards?
Also did you check that paths are correct and applicable to your Duo?
Also if you still want to start it manually, it should be:
/etc/init.d/pyload start|stop|restart
Whatever you choose to do it: start it, stop it, restart it.
Quick reference what are init.d scripts and how to use them: http://www.debian-administration.org/articles/28
